Dalton 68 base weights cut to 65
SnoPro1000
283
115
I have a set of Dalton 68 base weights and im
Not finding out that the adapt clutch needs much less weight to work.
If I return I loose 20% restocking plus shipping. Just not worth it.
Where would you take the weight off of them to make them 65’s?
Thanks for the help
spoon
Wrenching to ride is half the fun
1,236
642
Kootenays, BC
Offer up for sale to higher boost turbo guys. Take weight off and find still dont work for you and have junk weights is a gamble too.
madmax
3,151
Salt lake city
If they are team clutch weights they won’t work in the adapt. If adapt weights you can grind to the weight you want. Use a gram scale and make sure they all weight exactly the same
K
Nov 17, 2008
38
4
8
I had qa3-69 and we’re way to heavy went with qa3-61 you can weight them up to 70+ grams and stock is 61. So I’m hoping I will be in the ball park
