A couple of points... IMO
The 2.5" extreme IS a great track in this sled. Huge improvement over the 2007 series 5.0 track.
The Polaris IQ-RMK's 2007+ use a 2.86" pitch driver. The 2006 and earlier use 2.52"
The Challenger extreme 2.5" is available in 144, 146, 150, 155, 156, 159, 162 and 163 Inch lengths.
The 155 and 163 are the only ones in the bunch that are 2.86" pitch. The others are 3" pitch tracks. Some on here run the stock 2.86" pitch drivers with the 3" pitch track ,,, but, IMO, I really would not recommend that. The driver has to constantly ride on the edges of the involute nubs or extro teeth.
The only drivers available in the 2.86" pitch for the polaris tubular driveshaft (2005 and up) are 8 tooth .... stock and Avid.
Clearance is an issue with the
STOCK 2.4" track... too much parasitic drag.
Open it up and more power gets to the snow and the clutches dont have to work as hard to do it.
IMO, With a stock 700 engine (even with a pipe). No need to change to Combo drivers. The camo extreme 2.5" is now available in a 2.86" pitch and can be used with the factory drivers...Your 2007 does not have the center Extrovert driver... so no worries there..... IMO... on the 2008/09,remove the center extrovert driver as it can cause more problems than it is worth and adds to the weight of the driveshaft (the 2010's might not have the center driver from the factory) . On Higher hp/torq motors and turbo/nitrous installs.. the Combo drivers are a very good idea.
The Camo Extreme 155" is about 8 lbs heavier than the track you have now.
IT IS important however to run proper FACTORY recommended tension on the track.
I do Highly recommend a Drop and Roll with this track. Fastrax, Holz and Fabcraft make kits... they are all different so look into them before settling in on one.
D&R's bring the track closer to the top of the front-track shock/pivot-tube.. As you shrink the size of the driver diameter, you bring the track down closer to these parts..... so you have to watch out for tracks rubbing on the suspension.
The clearance issue on the RAW Chassis is not at the front of the tunnel opening where the heat exhanger is... it is at the roof of the tunnel. AND...YES removing the heat exhanger does improve the clearance and you will have more power to the track with more clearance.
Read these posts for a better idea of what is going on.
http://www.snowest.com/forum/showthread.php?t=153321
http://www.snowest.com/forum/showthread.php?t=79868
http://www.snowest.com/forum/showthread.php?t=44750
http://www.snowest.com/forum/showthread.php?t=125429
http://www.snowest.com/forum/showthread.php?t=95809
http://www.snowest.com/forum/showthread.php?t=123561&highlight=extreme
