Cutting/extending AFR wiring
3
347strokin
I'm relocating some gauges and may need to cut/extend some wiring on my AEM AFR gauge. What do you guys think of this? Will it mess anything up with readings?
I would like to extend the wiring directly from the sensor so I can just unplug the factory connector to remove my hood. (The gauges will be installed on the hood).
This has been discussed before but I can't find any real conclusions.
I cut mine when I first installed it no problems.
Just keep the wiring the same (ie green to green, white to white, etc) and I used solder connections with double shrink wrap, and I haven't had any trouble.
You might look into a Bosch style connector to use for removing your hood. They're more weather resistant than other connectors.
