SOLD
Kit started out as a push kit then the turbo was changed to a garrett 2871 with a PCV fuel controller.
Would sell as a 100% complete kit
2 fuel controllers (PCV and Attitude)
Turbo pipe
O2 gauge
Boost gauge
POD-300 gauge
Turbo oil pressure gauge
Low compression RKT head (have high compression domes too)
Full clutching (D&D magnaforce adjustable weights, 35/44P helix with springs to match setup and shift assist, also have a straight 44 helix)
Turbo with charge pipe, BOV ect.
Setup for a cold air intake
Oil pump for the turbo
Fuel pressure accelerator
1:1 rising rate pressure regulator
Will work on 2007-2011 m8s, kit should work on m7s and m1000s too but you would most likely need a different controller
Kit is still on the sled and is staying on unless someone wants it. Crank sheered off so im selling either the kit and sled separate or the sled with the kit.
![IMG_3494.jpg IMG_3494.jpg](https://www.snowest.com/forum/data/attachments/206/206062-7c66ad00918af1a9da5d20729cf9fdfd.jpg?hash=fGatAJGK8a)
Turbo pipe
O2 gauge
Boost gauge
POD-300 gauge
![IMG_3493.jpg IMG_3493.jpg](https://www.snowest.com/forum/data/attachments/206/206053-d3c1b586579bba068b47da2a19a48406.jpg?hash=08G1hlebug)
