It'll have four corner boxes, just steel diamond plate deck, 3/16 thick. Then I can mount anchors anywhere if need beThat's a great start. I would take my time too. Are you going to skin the sides or leave it open? What are your plans for the top deck?
I cares, want it to look fancy. It's already quite high just being on a f 350. It's all heavy steel, I don't need any unnecessary extra weight. It's about perfect height now for working off of. The expanding ramp will be nice too, I hope@joshkoltes why not just do some short cross members on top of the frame rails, then make the ramp slide full width on top of those? Yea it might make your deck height slightly taller but who cares?
This is the custom flatbed I had built by RacKustoms & Fab in Edmonton, Alberta.
View attachment 344693View attachment 344694View attachment 344695View attachment 344696View attachment 344698View attachment 344699
try these or something like them. I found these several years ago and they have worked very well for several projects.what kind of hinges are you guys using for the extendable sides that ride vertical when not in use and drop down to 90 degrees when in use for the 2 sleds configuration? thank you in advance. I have been going down many rabbit holes researching hinges and I appreciate leads. - JT
I bought material to just make my extra side extensions removable, but Haven't built em yet.what kind of hinges are you guys using for the extendable sides that ride vertical when not in use and drop down to 90 degrees when in use for the 2 sleds configuration? thank you in advance. I have been going down many rabbit holes researching hinges and I appreciate leads. - JT
