Wide bearing is not the fix. READ that thread that Markis24 posted the link to. Indy Specialty's bottom end is the way to do it for pure long term reliability, but if you're like me you'd rather squeeze a year or two more out of the Edge on the "cheap" and save for a newer chassis sled. If that's your situation, I would send the clutch to IndySpecialties to have Dan balance and shim the primary, he'll go through the clutch entirely, make it better than stock, charge $130 plus any bushings (he'll recut the sheeve faces if needed, its not overpriced for the degree of attention to detail he puts into them!). Make sure your crankcase is not beat out and still puts a
little crush on the crank bearings. Get a rebuilt crank from JJ Machinery in Utah (
http://jjmachineryonline.com/snowmobile/snowmobile-crankshafts/polaris?product_id=51) and some replacement pistons (they have probably collapsed some near the skirts but a caliper can confirm or refute this). Clutchman on here told me paper cylinder base gaskets tend to leak, so run the Polaris OEM cylinder base gaskets with a metal core, and ride the hell out of it. If you're running twin pipes watch out for detonation, that will wreck any motor but the stock heads on these motors make for high dynamic compression with twins and can be deto prone. Hmmm I think that's about all I know, and I'm just regurgitating what I've picked up from others.
Oh, and warm that sucker up before riding it hard! Aluminum expands faster than steel, so your case expands, loses its "grip" on the bearings, then the bearings expand and the case can "grip" them again, but you don't want to be riding it hard during that brief time of case/bearing temperature inconsistency. And of course there's the more obvious reason to warm up an engine: pistons expand faster than the cylinders, so WOT right after startup will give you a 4 corner seize, bet a guy would feel pretty stupid doing that!
I run a solid engine plate instead of the stock 2 strap mount, and an SLP push arm. Make sure your engine mounts aren't torn, that's really common with the stock engine mounting setup. I haven't torn a mount yet with that 1 piece plate though.
Don't feel too bad either, my engine is on the bench now! Lost the PTO rod bearing, MAG crank seal, MAG piston, MAG main bearing, MAG cylinder last March. Yeehaw
