Crank Case Troubles
jbusch
I blew the crank bearing and cracked the case on my 05 800HO summit. Does anybody know what other years will fit this case? Also, does any body know where I can get a used case? I only need the lower half.
01- 06 ,On the 01 you have to grind a little of the notch away on the stator side ( a little aluminum) to get the stator to fit flat and you have to have the timing checked
You problably want to change them as a set. Buy both top and bottom. I am pretty sure they are line bored as a set and to get the proper fit on the bearings, you will need the match set.
