What do you use to seal the crank haves.
thanks
thanks
thanks
1217H
Has excellent resistance to engine oils such as SJ-oil.
Has excellent initial resistance to pressure.
Has high elongation and withstands vibration well.
Has excellent resistance to heat and cold.
Retains the elasticity of rubber in a wide range of temperatures,
from -60°C to 200°C or even, briefly, to 250°C.
Is a deoxime type and does not sag.
Used for sealing of surfaces such as those of oil pans of automobile
engines, chain cases, and oil pumps.
1215
General-purpose liquid gaskets.
Excellent engine-oil resistance.
Excellent gear-oil resistance.
Corrodes copper and copper-based alloys. Can not be used for
copper and copper-based alloys in tightly-sealed state.
1211
Low viscosity, fluidic, and excellent workability.
Can be used with solid gaskets and it can be used for temporary fixing
of O rings.
Corrodes copper and copper-based alloys. Can not be used for copper
Sledguy:You use 1211 on the case halves? I don't use that, too thick for my liking. I use 1194 for the case halves and then 1211 on base gaskets.
