Alright guys, so recently my primary clutch cracked right in half, I thought it was just wear and tear, then I get the primary off and the motor mount behind it is cracked, alright I guess that can happen, then I pull that off to put the new one on and my bulkhead has a head crack going straight through it right behind that!
Ill attach a picture.
Sled is a 2007 M8 TURBO running 8psi boost so it does take a decent amount of stress.
Just need some advice if it can be welded up or if its time for a new bulkhead... Or if its time to do my first part out on a sled?
Any reason you guys can think of for this much damage happening from a cracked primary? This all happened right when a belt blew.
