I warned you that the motor mount bolts will loosen. The nordloks should solve your problem, I never had them come loose after I did that. Make sure you put the nordloks on both sides of the bolts. I am sure the extreme vibration is what caused your head bolts to loosen.
U only get EXTREME vibration when motor mounts come loose. Even your KTM will EXTREME vibrate if the motor mount bolts come loose. Its the powder coat problem we talked about. I bet if you just put it back together they wouldn't come loose again with a good lock nut or loctite as long as the powder coat is now down to the metal under the heads and nuts.
OK nothing loose... all bolts seemed torqued right.. but it was leaking coolant...so I will swap some rings, add some nordlocks then see what happensU only get EXTREME vibration when motor mounts come loose. Even your KTM will EXTREME vibrate if the motor mount bolts come loose. Its the powder coat problem we talked about. I bet if you just put it back together they wouldn't come loose again with a good lock nut or loctite as long as the powder coat is now down to the metal under the heads and nuts.
It does not appear to be.Carb hitting frame ? Steel frame i believe ? The Smarty comes very close to the stock frame. The Smarty vibrates like crazy compared to other options imo. I have some crazy video of the difference at idle alone. It kinda boggles your mind.
