CPI Turbo kit for Carbeurated 900 Mountain Cat, King Cat, ZR
I have a used CPI turbo kit that is still in great shape. The Turbo is a Mitsubishi Evo 3 turbo and it is a complete kit with the exhaust, Intake with blow off valve , oil pump and oil tank, fuel pump, and rising rate fuel pressure regulator that increases pressure as it builds boost, a manual boost controller, a fuel pressure and boost pressure guage, an AEM ugeo wideband air fuel ratio guage, a battery and the electronic equipment to make everything work , and the carbeurators that are set up to run on boost.
The turbos waste gate opens at 9 lbs which I was told is around 220 Hp and with the boost controller you can adjust the boost higher, at 12 lbs of boost its around 250 Hp which is the highest boost that you can run on AV gas, If you run better gas you can keep turning it up and have more fun.
I only put 100 miles on it but it was used when I got it so im unsure of the total miles on the kit but it worked awesome but one of the few times the skis were on the ground I managed to hit something and bent the front end up and ended up totaling the sled so im selling the parts,
My names Eric Give me a call if you have any questions
I am asking $1500 for it
701-721-6449 Evenings
701-220-0796 Days
I will get pictures up shortly
Here are some pics....
