Have a 09 m8 hcr with cpc stage 2 kit on it running 6-7 psi on pump gas at mostly 1000 to 2000 feet, have a cpc low comp head on it
Now to the sad part..
It has started to do most likely a "lean bog" after i comes of WOT and goes back on the throttle, sometimes it bogs so much that it will throw me over the bars.
It is bogging even at low rmps like 3500rpm and if i hear it sounds to go bad and a little lean i can kill it if i go WOT then.
its running like a god about 200-300 meters on full throttle and then its seems to lose much power almost like the clutches changes "gear" too fast but its not the problem..its the engine that looses power, and just when the skiis touches the ground the power comes back again and it runs perfekt. but when i let off the throttle then it starts bogging real much until it has stabilised.
Have checked the reeds and they looks just fine.
Have also new graphite muffler seals and springs and cant see no cracks or leaks at y-pipe or the pipe or something like that.
Have also tried to give the sled more fuel by the attitude box at green and yellow, have take it all the way up to step 8 and the problem still remains, but i have the green and yellow normally at 2.5 and that has worked just fine earlier.
The fuelpressuage is at 38 psi.
Beginning to run out of ideas now and begins to loose something else too (Hair..), had a problem earlier that it boosted to much but now that is solved after i ported up the wastegate port in the turbine and changed the flapper valve to a bigger flapper.
Hope you guys have som thougts about this problem and oversees my bad englisch..
