K
I added one of the CPC Proclimb Float Belt Deflection Adjusters to my 2012 Proclimb. This idea really makes sense to me. As the clutches engage and dis-engage they move and cause the belts to deflect. CPC claims up to 50 degree F lower clutch temperatures with the addition of the adjuster. "This Float/Belt deflection adjuster will perform 2 functions: First it will allow the driven clutch to float left or right on the jackshaft to self-align itself regardless if the driven clutch is partially shifted out or at full shift. This allows the driven clutch to float and perfectly align with the drive clutch and lowers clutch temperatures up to 50 degrees Fahrenheit. Lowering clutch and belt temperatures will extend belt life! Second, it will provide a quick easy way to adjust and fine tune belt deflection adjustment."
This seems like a reasonable fix for the machines that blow belts. What are your thoughts??
