CPC Helix for the M1000
sledcat
New member
CPC Helix for the M1000?
any one tried the diamond drive 38 degree helix and red spring on there M1000, how does it work, is it worth it.
I assume you are refering to the compression set up.
I run the CPC torsional conversion with 38 helix and red/wht spring, works great.
on a side note, are these helixes smaller (dia) than the old ones?
RS
My sled is stock, with a can. what is the compression set up
Stock is a compression set up. The spring compresses only.
Prior to the diamond drive in the cats, they ran a torsional spring in the secondary.
Aftermarket companies make torsional conversions for your sled.
It can be debated as to weather they are better or not, but they have more adjustment than a compression set up.
It is a compression spring with tabs on the spring to adjust torsional preload.
