Snopro_69
Hey just wondering if any or you guys with PC kits (or even M kits, same regulator) have trouble building pressure?? My stage 2 when it's cold out I have to whale on it at least 20-30 times for it to spin over fast enough to build pressure. Also it doesn't hold pressure for real long time when shut off. My buddies M will hold pressure over night! It doesn't leak any fuel on the throttle body side so can it be failing an passing the pressure back?? Going to do a test an seal the outlet (throttle bodies) right at regulator an see how long it holds it then.
