Looking for info on the coolant temps on my snowbike set-up and what others have experienced. I have a 2017 KTM 450 XC with a Thermobob and Trailtech Voyager gauge connected to the temp probe. The gauge is reading 236 F temps (it was climbing so I shut it off) and not sure if the gauge is reading wrong or because of the location of the temp probe on the Thermobob is so close to the coolant out of the head. I used an infrared temp gun to verify temps coming out of the head to the Thermobob housing and they were high indicating the gauge was reading correct. After the radiators on the coolant back into the engine, the temp had dropped pretty good indicating that coolant is flowing. This was in the shop after a quick test ride and not out on the trail so I'm not sure if the high temps is because of no air flow through the radiators.....
So the big question is: what is normal coolant temps out of the engine into the Thermobob housing? Will temps read high all the time on the coolant immediately flowing out the engine?
thanks in advance for any info.
