Q
-Q-
New member
My 2006 Summit X 1000sdi started leaking coolant. Strange thing was (to me, anyways) that the coolant was running out from under the seat/gas tank and on top of the tunnel all the way down the flap on the back (as well as down the sides). I popped the side cover open, and it did not seem to be coming out of the overflow tube (although I'm unsure on this), and the cap was on tight. It leaked a BUNCH of coolant...I had to top it off to get it back to the parking lot.
I pulled the seat tonight, and the rubber lines that come from under the gas tank appear to be in good condition and the clamps were on tight. I couldn't see any evidence of a leak there.
Would it be possible for coolant to drain under the gas tank/seat towards the back of the sled if it were overflowing out the overflow tube on the resevoir? I initially noticed the leak after I had been in some powder, so the sled would have been elevated in the front, which could cause the coolant to flow towards the rear. Wondering if my cap is bad...
Suggestions?
Suggestions?
