O
Oregonsledder
Last weekend I rode my 12 PRO 800 on Friday. We had 5 feet of new snow and I had a blast. We were camping for the night and the sled sat outside under it's poly cover. The next morning it started normally and then after warm up when I was ready to get after it, I would get to about 3500 RPM and the check engine light would come on and it would go into limp mode (at least that is the way it seemed). After running around the snow park a while it quit giving me the error and it ran great the rest of the day, with no issue.
After getting back home, I started looking around and found the TPS dripping with coolant.
I pulled every thing off needed so I could get a good look. I pulled the TPS cover and plug and dried everything out and filled the connector with dielectric grease (to keep moisture out in the future).
There is a coolant line directly above the TPS than runs from the throttle body to the PTO side head. I checked that hose very closely and ran the sled and there was no moisture any where around that hose or it's connectors.
My theory is this..... If you look where the coolant bottle over flow hose is, it is in line with the back of the air box. If the sled was puking a little coolant, and was on it's left side.. (mine was a few times over the weekend) the overflow would run down the air box channel and onto the TPS connector.
I can't find any other way coolant got there, but I thought I would see if any one else has seen any thing like this? I'm sure the coolant in the TPS connector was why the sled didn't want to run on Saturday.
Input welcomed!
Input welcomed!
