converting a flatland 2008 600 RMK
I plan to take the sled to Yellowstone.
We will need a couple sleds but only have room for one. Any opinions as to the best place to rent one out there?
Thanks
Is it EFI or carbed? If its EFI you just need to change the weights,if its carbed you will have to change the main jet and possibly the needle position. Do you have the factory jetting chart for your sled?
1.22
Model Specifications
2008 600 RMK 144 / 600 RMK Shift 155
Model Number:
600 RMK 144: S08PK6FS / S08PK6FE
600 RMK Shift 155: S08PM6FS
Engine
Engine Type Liberty Liquid-Cooled /
Case Reed Induction
Model Number S3467-6044-PU6F
Displacement / # Cylinders 599cc / 2
Bore (inches/mm) 3.04 / 77.25
Stroke (inches/mm) 2.52 / 64
Piston to Cylinder Clearance
(inches/mm) .004 - .006 / .105 - .159
Installed Ring Gap
(inches / mm) .014 - .020 / .0356 - .508
Operating RPM ±200 8100
Idle RPM 1500
Engagement RPM ±200 3800
Exhaust Valve Spring Pink
Carburetor Settings
Type Mikuni TM38
Main Jet 280
Pilot Jet (Pj) 50
Jet Needle/Clip position 9DGN6-57 / 2
Needle Jet P-8
Throttle Gap (Under Cutaway) (in/mm) .125 / 3.2
Cutaway 2.5
Valve Seat 1.5
Starter Jet 145
Pilot Air Jet .9
Fuel screw (Turns Out) .5
Recommended Fuel Octane (R+M/2) 91
(Non-Oxygenated)
Carburetor Jetting
Altitude
Meters
(feet)
Ambient Temperature
< -25°F/<-35°C
-30°F to -10°F/-34°C to -23°C
-15°F to +5°F/-26°C to -15°C
0°F to +20°F/-18°C to -7°C
+15°F to +35°F/-9°C to +2°C
+30°F to +50°F/-1°C to +10°C
+45°F to +65°F/+7°C to +18°C
>+60°F/>+16°C
0-600
(0-2000)
440
#3
430
#3
420
#2
400
#2
390
#2
380
#2
370
#2
360
#1
600-1200
(2000-4000)
410
#3
400
#3
390
#2
370
#2
360
#2
350
#2
340
#2
330
#1
1200-1800
(4000-6000)
370
#3
360
#2
350
#2
340
#2
330
#2
320
#2
310
#1
300
#1
1800-2400
(6000-8000)
340
#3
320
#2
310
#2
300
#2
280
#2
280
#1
270
#1
260
#1
2400-3000
(8000-10,000)
310
55Pj
#2
300
55Pj
#2
290
55Pj
#2
280
55Pj
#2
270
55Pj
#2
260
55Pj
#1
250
55Pj
#1
240
55Pj
#1
3000-3700
(10,000-12,000)
290
55Pj
#2
280
55Pj
#2
270
55Pj
#2
250
55Pj
#1
240
55Pj
#1
230
55Pj
#1
220
55Pj
#1
210
55Pj
#1
When using non oxygenated fuel with a RON greater than 93,
decrease the main jet number in the above chart by 10 and raise the
E-clip one position. If the chart recommends clip #1, install washer on
top when using RON 93.
Clutch Settings
ALTITUDE
meters
(feet)
DRIVE CLUTCH DRIVEN CLUTCH
Shift
Weight
Clutch
Spring
Clutch
Spring
Driven
Helix Gearing
0-600
(0-2000) 10-62
140 / 330
(7043342)
BLACK
(155 / 222)
56/42 - .36
LW ER 19:41-76
600-1200
(2000-4000) 10-60
1200-1800
(4000-6000) 10-58
1800-2400
(6000-8000) 10-56
2400-3000
(8000-10,000) 10-54
3000-3600
(10,000-12,000) 10-AL
Drive Clutch Bolt Torque: 50 lb.ft. (68Nm)
Looks like needles should be in the #2. Another problem you might run into is gearing. I'm not sure about the flatlander shifts but my 08 600 rmk has 19/41 and is still just a bit tall for my preference. You'd be better off with 18/41 or 19/42.
290 mains should be ok and Bob Peppler rents sleds in west. He will deliver also to west and island park. his #406-640-1104 We have rented from him for 5 years or so. have fun
