Yep.I could see that. Polaris’ chassis is essentially 10 years old (minus plastics, tunnel, bulkhead, coolers, over structure, engines, boost, seat, console, gauges, headlights, tanks and fueling system updates)
Except the ascender uses the same bulkhead and tunnel as the proclimb, while the matryx doesn’t use the same bulkhead or tunnel.Those that think a 2012 proclimb is the same as a 2022 ascender have to say the Polaris Axys is essentially the same as a Matryx too lol.
The tunnel on the Cat looks the same, but it is not.Except the ascender uses the same bulkhead and tunnel as the proclimb, while the matryx doesn’t use the same bulkhead or tunnel.
Bare chassis looking similar isn’t the same as actually being the same.
I would say youre reasonable number is more in the 480 range and the crazy cost starts after that.With what I've observed on Catalyst parts coming from the aftermarket and free things I have done on other sleds It looks like a person could get a 154 3.0 track Catalyst near 470lb RTR with stock amount of fuel in the tank. The cost goes up SIGNIFICANTLY to get it to 465lb.
Will be interesting to see what they unveil. Seems like the Matrix still sells well. Polaris faithful are SO faithfulYep.
Might be tough. I thought I read they really lightened up the stock pipe.I’m hoping for a single pipe setup similar to the current 800. Add 10hp and drop 20lbs.
Haha I didn’t even notice you changed the quote. What a list. And a recall for every one of themYep.
Hence the new polaris corporate name. (Total Recall)Haha I didn’t even notice you changed the quote. What a list. And a recall for every one of them
Speedwerx is claiming 16lbs with a titanium can. Might be close with a pipe and titanium can.Might be tough. I thought I read they really lightened up the stock pipe.
