Con rods breaking on turbo etecs
chad006
Hey fellas, S&M has this exact thread thought i would start one here cuz I just kicked a rod on my 2013 aero etec 7lbs of boost 1000 km. What's everyone on here using for billet cranks/con rods?
Nobody wants to reply because we have had good luck so far and just as soon as we say we have never had a issue.....KABOOM!
In all honesty Brycter might be able to give a answer as they have been doing 800 Rotax turbos for many years.
Indy Specialties produces a connecting rod for the E tech turbo application.
Sent from my SM-G928V using Tapatalk
Blew a my PTO side rod 2 weeks ago. 650 miles 7 lbs. Big john should have me up and running shortly.
Sent from my E6782 using Tapatalk
Who's kit? Running premix? Did you get the oil pump turned up?
Silber kit. I usually run a splash of oil in each tank but forgot to do it the day it blew up. Weather or not that anything to do with it I have no idea. I have candoo lit haven't turned oiling up. This was my first trip out this year but my last trip last year. I was in the big horns and hit the det sensor 5 times. I am running 50/50 91/av. I don't no if I had bad gas or what but I think the det caused my rod to blow. I am a noob to turbos and the only in my group so I am open to any other suggestions.
I completely agree that the det was my issue. But with the fuel controller I have available to me right now it's next to impossible to be in perfect tune at all times. Not saying it is not my fault that it detonated because it was, however having a rod that will handle the first mistake I make without failing is nice. A second chance is always nice. Hoping to eleviate my inability to tune and have a new fuel controller by the time she's back up and running. :face-icon-small-coo
I also think that I may have had a crank that was no longer true, whether it was from a belt grenading at wfo or what I don't know. But it's my only explanation for the pto side being the only one detonating. If you ask around a majority if not all of the etec rod failures have been pto side.
Your rod broke exactly just like my friends. Has 300 miles on his and he blew a belt WFO a few days before. We have zero blueing of the lower rod, actually looks brand new. No det sensor or indication of anything wrong. It was his last day of the trip and heading home on the trail he let off and got right back on it and it was all over with.
I do believe det was a huge factor in my particular blow up but the fact that all the rod failures have been pto side leads me to believe that there is an underlying issue. Allot of guys have been taking rods out shortly after belt failure, it possible that the sudden loss of load at wfo is causing the cranks to tweak slightly with det being the finishing touch?
Nothing new here and it doesn't require a turbo. Engine #2 in my XP was just like your friends at 500 miles, rod exploded. I shipped it back to skidoo for inspection, as I felt I got a short block with a defective crank. It was a waste of time & money, in the end I broke out my checkbook & bought another short block. #3 lasted over 3000 mi. #4 isn't installed yet.
After thinking about this. I had a belt delaminate the day before. Didn't blow just had a bad vibration. Now I am wondering if that anything do with it.
ya the blown belt before broken rod is proving to be the case with most of the failures I have heard about. Might be more than a coincidence.
I didn't personally blow a belt on mine but I bought it second hand with turbo already installed. When pulling engine out last week I found allot of belt shrapnel so could be the culprit in my case as well. Just took a little longer to finally fail in my case.
