Complete welding setup! Mig Tig Stick
You can do it all with this package! Mig tig stick! Gas or flux core! Feeder runs wire from .023 to 5/64! Gas or flux core!
Lincoln invertec 250, Millere s32p wire feeder, Tig torch, stick leads, gas regulator, gas bottle.
Everything pictured is included for $1800 Or offer. Trades considered! What do you have?
Will send larger pics on request!
250 AMP LINCOLN INVERTEC V-250-S STICK & TIG WELD SOURCE
MODEL INVERTEC V-250-S
GENERAL DESCRIPTION
The Invertec V250-S is a 250 amp arc welding power source that utilizes single or three phase input power,to produce constant current output. The welding response of this Invertec has been optimized for stick(SMAW) and TIG (GTAW).
OPERATIONAL FEATURES
The Invertec V250-S provides continuous total range output current adjustment, selectable welding modes and local or remote output control. Welding characteristics can be controlled via an arc force control. Additionally, starting characteristics can be adjusted via a "hot start" control.
Miller S32P Wire Feeder
Processes:
* FCAW (Flux Cored)
* GMAW(MIG)
Features:
* Excellent wire speed regulation compensates for load variations
* Operates on either straight or reverse polarity
* Quick change drive rolls and quick connect for miller guns
* CC&CV selector switch-voltage sensing in CC, Constant speed in CV
* Overload protection prevents damage
* Solid State speed control and service life
* Built in gun holding bracket
Electrode wire diameter capacity:
.023-5/64”
Maximum Spool capacity:
30# Spool
Everything pictured is included!
Call (605)673-1558 weekdays or (605)673-5635 weekends or nights or respond to this add. If no answer leave a message and I will call you back!
Thanks for looking!
