We took out both 2013's yesterday for the first time and spent time on each of them. We were road only due to low snow conditions, but it was at least 24" of good powder. I feel like we need to make some adjustments to the Pro's suspension. It is stock what the book recommends, but the front felt heavier than the Pro-Climb did carving back and forth. It also felt like the rider input took more on the Pro over the Climb. The throttle response and smoothness was definitely noticeably better on the Climb. Hopefully the Pro engine will loosen up upon break in. Throttle spring tension on the Pro is much stiffer compared to the Climb too.
What are you mountain/powder guys running for suspension setups for around 200lbs? Could care less about trail handling characteristics. We were going to try loosening the front ski shocks to where they are just putting pressure on the springs with weight off. We also were going to crank up the front shock on the skid to try and make the front end feel lighter. How much is good below the spring retainer? Do we need to mess with the rear shock? Any input would be appreciated.
Aaron
Aaron
