stellar spring riding today...handful of stucks..saw 3 others sleds on mesa...they also were riding from tml...actually more ice fisherman out than sledders.
Jacob, any word on the headlights, a arms, and these parts?
SUPPORT IND. *INDICATOR SUPPORT
517304575
Please also order these
qty 2
ATTACHE VERROU *LOCKING TAB
513033135
qty 1
SCREW-SHOULDER
732601143
I'm guessing having a stoner as a parts guy is not going to work for you Dave.
Unless your in no hurry?
Be at the Ear's Sat-Sun.
Crank is done and motor mount plate will be here tomorrow. The crank guy says he thinks the remanufactured crank I put in (from racin station) was kinda bent when i got it (crank whisperer I guess). Now I'm kinda thinking that the plate that holds the two pto side motor mounts started cracking and that was what let the vibration be felt. As the crack got worse the vibration increased. maybe. Didn't find the cracked plate until quite a while into the process. Hard to figure out what caused what. Did the crank cause the clutch to fail, which tipped the point where the mounting plate failed or vice versa. Maybe the motor mount plate cracking caused all the problems. Anyway, he says the crank is straight and will work. Only $160 for the work, so I hope I get lucky. My deto'd piston has me back on 91 octane again as well.
