code 43 on nytro
Code 43 Fuel system voltage (monitor voltage) Power supply to the fuel
injectors and fuel pump is not normal/may or may not start
PM your email and I can send PDF file of manual.
Autopro
Code 43 Nytro
Fuel relay is wet and then at night time the dash will be on and draining battery.
Make sure you mount them upright in dry location.
Jumper wire from battery to fuel pump will get it started and home most times.
www.powderlites.com
same happen to me, and i just keep turning the key on and off till if fired back up, never had a problem since my garage burnt down and took half my sled with it
