Anyone had experience with this code? Last weekend I had my sled shut off 2x because the large size fuse....10amp up near the front kept poping. I assumed either my fuel pump was starting to fail or I had some sort of short? I did find a potential problem where I plug my headlight into the aux power outlet and may have been shorting up there? I had to jumper the fuse in the end that day to get it to run. It would only pop the fuse at WOT. Next day after unplugging my headlight and drying things out the code was gone and it worked fine.
Also when jumpered (and still had the headlight plugged in and throwing the code) you could tell when starting there was another drag on the battery as it was harder to turn over.
Thoughts?
Thoughts?
