Code 11
T
twsandrew
09 M1000 turbo started throwing this today. Ran fine up top but wanted to die starting out like the temp sensor switch wasn't working. I looked up the codes and find pretty much everything but 11. Any input?
Thanks guys. Just to clarify. There is no - in between the 1s. I just checked it. That is code 2?? Based on the behavior injector seems possible just want to get some idea before I start looking or before I have to call Shain like usual.
That's what I thought. Talked to Shain. He said it is likely code 17 and the top of the 7 is just not showing
You can ohm the pipe sensor and it should be around 220 cold. While you test it wiggle the lead and see if the meter reads open.
Its working well, better than any POS pipe sensor. Just be sure to take a little warm up lap before pulling any big hills. BTW had an awesome ride yesterday, amazing what a working CCU will do for performance and hand warmers:face-icon-small-hap
