clutching with slp pipe and regaring
ive bought some stuff for my piped (slp)rmk 06 900 166".got a New helix tss-98 58-44.46 With stock spring .primary :76 gram 11 serie polaris weight black spring .regearing to 19 42 and im riding at 2000 feet i think it
is going to pull way to much rpm .maybe some other springs for primary secundary?
your right on track, but I don't think those springs will bite that belt hard enough..
I have ridden several diff altitudes using same spring (and setup you listed as well) and it was awesome.
You can get the springs from SLP or a dealer (but color is dif)
secondary spring is a black/white (its a Team spring)
and depending on the RPM engagement you here is what I recommend in order of lower rpm to higher
--black/pink (slp)
--black/green (oem)
--blue/pink (slp)/almond (oem)
