Clutching set up 2016 hcr 8000
Hello folks,
Looking for a little help with clutching set up on 2016 HCR 800..Riding 2,200' - 7,000' --Running 68 gram weights and 48 degree helix ,cant remember which spring in primary im thinking 180 - 285 has high engagement,like the low gearing for know but I thing it should pull harder.
HCR same issue
Same issue with my HCR,too high of engagement change out primary spring to lower start rate,does not pull at all hard on the top end kinda runs out,going to try softer secondary spring and adjustable weights
