Ok so my 04 has the new quiet pipe and I am having some bogging issues in the deep stuff.
I have rejetted to 06 stock 15pilot 400 main. Seems to start up and run fine.
I have a stock 50 helix with beige spring, stock primary.. I have adjusted the secondary to stiffest setting and it seems to have improved the situation.
The only difference I can see with my setup and the newer 06 is the secondary helix, the newer stock one is a variable 50 44. Do you think thats my problem?
Do I buy the newer helix, does the variable 50 44 really make that much difference. In theory it seems like that is exactly what I need.
Do I get a stiffer spring and keep the same helix?
Do I buy a new Beige spring since it may be worn out?
When do I consider changing the main or lowering the needle?
Any help would be appreciated ..
Thanks
TonyC
Thanks
TonyC
