Clutching on zx chasis
I am pretty new to tuning my sled and I was wandering what clicker setting has worked best for you guys. I ride in central wa, roughly in 2-5000 feet elevation. Right now mine is on 0 and I am just looking for a good starting point to start fine tuning. It is a 03 summit 700 144 what has. thanks
I believe mine are on 3 it was set up 6000 ft (I think) I ride at 8000-10,000 ft now I dont know if it right or not it's just where mine are set. 03 800 summit H.O.
Can it,WOT, read rpm's, should be around 7850, if you can't get rpm's up to that point move clicker to next higher #. We run ours around #3 for the 8000ft range. just my .02
i run my clickers on 1 and it terns 8200rpm all day. for money i will tell you the spring ramps helix and poundage on the secondary. you will eat up any new sled. ive seen me do it.
I ran solid pins in my primary. I had the clicker set on #5 with a worn out spring. When I changed the clutch spring I moved it down to #3. I was riding that sled anywhere from 6000-8000 ft. If you don't have anything done to your clutch try throwing some weight to it abd see what happens and how you like it. I loved mine after that mod. :beer;
