I have a 2014 M8 162. A stock sled aside from a mbrp can. I wanted to lower my Engagement into the mid to high 3000's
A mechanic set me up with a black/silver (110-290) primary spring. I pulled the stock yellow/white(122-285) it was engaging 4400 ish. I was surprised when the black/silver only dropped engagement to 4200. Primary is clean 68gm weights are good , everything slides good. Can anyone make suggestion as to why it isn't engaging at the 3500-3700rpm as indicated by others using the same setup?
Thanks in advance for any suggestions.
