Clutching guru near bemidji,MN
I have a 04 700 RMK w/ 159 on it. Does anyone know of a good clutch shop near Bemidji,MN that would do work on my clutches? Need to havethem looked at by a pro. thanks for any input.
Well I assume by your question that your not into wrenching much. If I were you I would get a service manual, you'll get a good set up from guys on here, and learn to do it yourself. Most basic stuff is easy to do, buy a few tools for the money you would spend at a dealer and then you`re set for further tweaks down the road. Most times someones elses set up will get you close but your sled might need a small tweak to get it spot on once you've ridden it a bit. Keeping them clean is important too, that`s something you can do for sure on a regular basis.
If thats not you're gig, Indydan on here has a great shop in MN. and I think he does them.
IMHO clutching is the key to :peace:riding all day long no matter what size engine you have. I ride a piped 800 so my set up would probably a little off.
Also do a search on here and look at the `Sticky`post at the top called ìncreasing your IQ I think and you will pick up a lot on clutching.
Good luck!
