Clutching for RX1 Turbo
Did you install the turbo on it or did someone already clutch it with the turbo setup. Main thing you want is to have your rpms around 10,600. So clutching depends on how much boost you're running.
RX1 Turbo
I had the turbo set up done by a builder, actually went from a 2560 up to the 28, I havent had it out on the snow yet to really test it, we are thinking that it may be alright the way it is but may go to a Dalton set up with 66gram base weight. I want to run around 18 lbs most of the time, but want to be able to dial it up for some of the extreme hills and drags etc.
