Eric-The secondary greatly benefited from a better helix.
For the primary I would run MDS with an H5 alloy spring.
Hey Eric what is that h5 all about I got a plolaris black from you and mds and helix. Also is there any point adding the spacer in the secandry clutch like the 2013 have
You have the side plate. It is a plate on the side of the weight toe. All of the M1100T weights have this.
The Polaris black spring is a good rate for the stock turbo. If you are running higher HP let me know and we will get you set up.
The H5 alloy spring's benefit is that it won't sack out like steel. It lasts like titanium with steel price.
The spacer for the secondary is in your update kit, that has not shipped yet.
