I can't find torque specs to my clutch so can somebody tell me the specs for spider, spider nut and primary bolt? My sled is 16 pro rmk 800
Per the Axys manual:
Spider: 280-300ft-lbs (apply Loctite 243 or 242 w/Primer N)
Spider Jam Nut: 290-330 ft-lbs (same Loctite usage as above)
Drive Clutch Bolt: 80 ft-lbs (Re-torque after running engine)
i am no mechanic, but that seems extremely high.
are you sure you don’t mean inch pounds???
300 ft/lbs in an enormous amount of torque
