clutch tools
goforbroke
I want to replace the secondary clutch spring. I like to do all my own clutch work, but the only secondary compression tool I've found is $80. Anybody have a better alternative?
Thanks
u could make out out of threaded rod.. and some plate..
But the tricky part to make the the Pusher..
look at SLP tools..
Thanks
Matt is right, the slp tool is the way to go. Yes, you will have to pony up the $80 plus dollars. Get the clutch tool that compresses both clutches, and has the two fingers to press the secondary. It makes it simple to change springs, to clean, or add delrin washers.
