D
Danbot
Searching led me to no information on taper repairs on clutches.
At the end of last season my clutch bolt snapped, and the clutch popped off, making for a long weekend of hanging out at camp watching sled vids while everyone else rode the pow.
Anyways,
When the clutch came off, the taper made contact with the end of the still spinning crankshaft for a moment leaving a small mark on the clutch taper. I sent the clutch out for full checkup, balancing, and to get the taper touched up. They shop told me that the machinist says he can repair the taper but depending on the material needed to be removed the clutch may sit "a little" closer to the engine.... makes sense.
If I understand how the float on the secondary works... the float is on the inboard side of the clutch under power. Is this correct?
It would seem to me that no more than a couple thousands of an inch would be necessary to be removed in re-setting a clean taper in the clutch, but until my clutch is ready I don't have those specs from the machinist.
Going with this assumption for now.... will I need to compensate for this small difference in the float or would it be considered insignificant?
I know I should be directing these questions towards the shop with my clutch, and I will.... but I am getting a little upset with this shop with some other issues including but not limited to: trouble getting the proprietor on the phone to discuss this. I won't rant about the shop... but they are a reputable mod shop and I'm still not expecting shady business, but I'm getting impatient, and maybe panicking a little
Indydan, you will be getting my hard earned Canadian $$ for clutch work in the future! Should have gone to you first
Anyways,
