Clutch setups with 2.6 track
Ron Burgandy
For those running the axys 2.6 track on the pros, did you keep the clutching stock or adjust it? Will the stock belt drive be low enough for the extra track lug?
Think most will agree, but the stock belt drive wasn't low enough for the stock track. When I say low I actually mean a higher ratio, more low end.
i have the 2.6 track and the 7 tooth driver 2016 driveshaft. i run stock primary spring, 60 gm weights, and black purple secondary spring. i ride from 7000-10000 feet. my sled will pull 8200-8300 throughout the ride.
Sorry if it's been asked/answered elsewhere, but does the 2.6 fit with stock Pro drivers? I have a Kurt's gear down kit just sitting there collecting dust, so the re-gearing issue would be looked after...
the 2.6 will fit the stock 8 tooth drivers, I did the 2.6 with the kurts gear down and it is a awesome upgrade from stock
sounds like the consensus is the clutching is fine if you gear down via 7t axys drivers (are those the right pitch?) , kurts gear down kit, c3/TKI.
Whats the advantage with kurts gear down vs. c3/TKI belt drives? It seems to be fairly popular
