I saved this from Darko last year.
If you want a drag racer, load up the tip, it will hole shot awesome but falls off on long pulls, if you want a climber load the tugstens on the heel and tune the mid and tip. (Supertip style weights).
I ran supertips and did away with them.
If you wanna run 12lbs of boost at (true riding elevation) 4000 to 7000 ft try the Yamaha 8BU's with 2 steel 17.2 gram rivets pounded in them.
If you wanna run 15lbs, run the Dalton DPYR 66gr (base weight) with 17.2's pounded in them.
17/18 lbs, run the dalton DPYR 70 (base weight) with 17.2's pounded in them.
Also, change your rollers to 14.5's (yamaha), run a blue white blue primary spring (a little higher engaugement) or for a little softer engaugement run the blue pink blue.
Standard yamaha helix, go with a regrind at straight 51 (Avail at Vernon Motorsports for an exchange and 50 bucks or Alpine for exhange and 60 or 70 bucks). Or a roller rooster secondary run a 45 straight cut.
In the secondary, run a stiff black spring from Alpine. No belt slip and helps eliminate the belt staying down in the sheeves when you let off of full throttle in a hurry while in the deep pow.
The Apex and RX1's are very picky on the type of weight profile you run in them. Some guys love the supertips, i didnt. Regarless of what kit you have (Boondocker, MCX or Alpine) the above will work well. Lets be honest, they all make very similar power regardless of who chimes in saying there kit spanks another kit. It's BS. Boost to boost its the set up that will shine in most cases. Each kit has there pro's and con's, choose the one you get the best support from and the one that suites your riding style etc. I ran these combo's above on my MCX and my Alpine and had the same results. (A good hard pulling sled that doesnt use belts, heat up the clutches etc)
*Note- When i leave the parking lot at 1904 feet, i will hit the rev limiter with all those weights and boost as said, till about 4000 feet. (Our riding here gets good at 4500 to just over 7000 feet). After that she holds 10,300 to 10,600 and nothing but a big grim on my face.
Trust me, the above set up works !
Sorry to hijack your thread since i dont own a Boondocker, but i've had on hands exp clutching these monsters and figured i'd share my opinion.
