I wouldn't spend any money on Skidoos Clutch Puller. Everytime I went to remove my clutch, I had to go get a new puller from the Dealer.
The Skidoo puller is soft and would start to corkscrew at the tip where it pushes against the crankshaft. When you start with a new puller the part # is straight inline with the axis of the puller. After you use it, the same # wouldn't be in a straight line anymore.
After buying the aftermarket puller, removing the clutch was easier, taking way less torque to break it free from the crank. It used to take up to 120 ft-lbs to remove it. It was especially harder when Skidoo increased the bolt torque up to 89 ft-lbs, about halfway into the 07 season.
