Clutch Help- 2012 800 PRO
2012 800 pro 155 elev 3000-6900
What's is best pro set up for this elevation for gears and clutching.
Rider weight with gear: 225
What I think will work
19-41 stock chain
Blue/pink 140-340
Stock weights 10-62 or 10-60
Rear secondary stock from factory?
I need an set up pro to tell me my math for 8250 rpms and if combo action is off what I need to switch up??????
I would start with 10-64's. We are the same altitude and some even pull 10-66's. All else the same or close.
More weight
I agree with winter brew, all things stock as you stated, you need more weight for that sled and elevation, in my opinion if your going to run all stock except for spring, for about $250 you should look into MDS Clutching, run their weights at about 68grams, with a Polaris Black/white primary spring(120/340). Pulls harder than most set ups I've ever ran. Call Steve at MDS and he'll set you up right, www.mdsclutching.com. If you don't like them you get your money back, pretty good deal. Lots of good set ups out there, ask around, find a dealer/guy close to you or readily available for advice and help and let er rip, good luck
