belt is slipping in the primary, only on the bottom thou. leaving alot of rubber on both inner and outer sheaves. first thought was alingment was off. i have tried to tighten the belt up and loosen it neither of which helped. i have a 140 start rate in there for a spring. its not slipping in the secondary. i have not measured the clutch to see how much gap is in between the clutch and belt.
