Sled makes a loud noise when clutch engages. Any ideas why?
You commented it has done it since new. If deflection is good, disassemble the secondary and check that the components are all there.I will check deflection. It has do e it since new. 250 miles now. Just put in TRS clutch kit and changed weights, springs, helix. Noise is the same every time. I checked primary belt to sheave clearance. I haven't checked deflection. I'll do that next.
I took secondary apart. Rollers look good. Spring and cup look good. Put in new spring. Still need to adjust deflection.You commented it has done it since new. If deflection is good, disassemble the secondary and check that the components are all there.
Getr done! This is something you should do before you go on your first ride, and every few rides after that. Takes 2 minutes.I took secondary apart. Rollers look good. Spring and cup look good. Put in new spring. Still need to adjust deflection.
Heck I keep an Allen wrench and end wrench in my handlebar bag and adjust deflection on the hill as needed just because I dont like giving up performance. It takes less time to adjust than stopping for a drink of water. Belt deflection is critical in having proper performing clutches. If it's to loose it's like starting off in high gear and affects performance all the way through the shift. It's also hard on belts having it to loose.
