clutch engaging at 5500 rpms.
Installed mds weights. They are 87 grams. weight distrubuted as follows
Plate
Short button w washer on tip
Silver bolt and washer on mid.
Gold polaris primary spring.
I am also having, it cut out or hitting rev limiter when i punch the throttle can happen from,low speed up to 50- 60 when i punch the throttle.
Any bhelp would be greatly appreciated
Plate
Information required: Sled modifications, rider weight, elevation please. Your engagement is high too, I'd look for binding in primary & check belt to sheave clearance -belt deflection may be loose as well.
