O
overboard
New member
Hi. SLP Stage 3 with MTX weights - I took the clutch, minus cover and spring to dealer (could not get the thing apart without special tool). They shimmed it to the correct width with a broken in belt.
So I started thinking, the spider dictates where the cover orients (line up the arrows), but if the spider is now off by 120 or 240 degrees, the cover will also end up out by that much.
Are the sheaves balanced separately from the cover then assembled, or is the entire clutch assembled and adjustments made to both cover and sheave (at factory - I know a balance is done on a full clutch).
Where I'm going with this is questioning whether I need to re-balance my clutch. I know the manual says the spider makes only a small difference in balance, but is it critical that the cover matches to the alignment with the sheaves ? I did not mark this so if it is a relevant factor, I guess I'll need a balance & if so, who does balancing in Calgary AB area ?
I'm going to read the manual again to see if I'm missing something obvious.
Thx.
Thx.
