The back mount is fixed. I guess you could shim the motor to the right, but that will do nothing for the c to c. Look at the manual and take the sled apart and you will see. There is a reason you can't find it in the manual, it can't be done ! The motor is more or less fixed front to back. If your burning belts then look to the clutching.
So when you moved your motor did you shim the left rear mount (no adjuster on that side) ? I had two Nytro engines pulled last week and the front of the bulkhead was very flimsy. The only way i could see it is if the left rear of the engine was shimmed over to the right.
Both nytros were more or less right on the money in the middle of the offset spec and seemed to be true and square. One was a new 2011 and the other a 2010 with just under 1000km. If they are out of spec then the sled is bent IMO !
