clucthing help for mcx nitro
any advice would be great stock track i have tried many secondary set upsprimary has mcx weights in it sled revs at 8300 and if in deep powder will drop to 7900
You need to give way more information then that. There are about 12 things you need to include before asking for clutch info. Search and post and we will see if we can find you a better set up.
clurching
58 gram fully loaded,stock spring or pink I think primary, secondary you could try shockwave and green cat spring.
By no means the best clutching but I found it ok and I didn,t blow belts. I have also tryed the dalton weights fully loaded and keep blowing belts if I was on and off the throtlte in the trees.
Cheers
8BU fully loaded.
14.5 rollers
b/w/b primary
shockwave helix........2 turns out
EPI purple spring set at 1-0 as the timing on the Cat spring differs from the OEM.
I run that from 15-17lbs of boost
^^^X2
I am running a 47 degree helix instead of the shockwave though. Sounds like his shockwave is set at 50 degrees. 1/4 turn per degree. Starts at 58. Right?
8BU fully loaded.
14.5 rollers
b/w/b primary
I run the same except 74g daltons.
I'm running the 8BU's loaded up and they are out of the sled so I'll weigh them and post it if noone else has by tomorrow,also running the shockwave helix seems to be easy on belts,and can save the day if clutching is way out of wack.:D
8Bu-00 are 47.7 grams empty. Loaded with 4.5 grams in each hole is 56.7 grams. I know they are not that heavy but they do work.
8Bu-10 are 45.41 grams empty and are a little different profile.
I have a set of 8BU-10 weights if anyone needs a set... they are brand new and still in package. PM me for price
Part # 8bu-17605-20
