Clearance Light Short-Circuit
J
JohnnyQuestUtah
What a trip!, I had a clearance light "base" shortout on my 27' enclosed.
I know it dosent sound like a big deal, but it kinda was.
after the light "base" had shorted it really messed up my electric brakes, any time I even touched the brake pedal the trailer brakes would lock up.
Also , if I turned on a blinker light it also locked up the brakes :confused:........the brakes would go on-off on-off just like the blinker lights. did some real dandy "hoppen" down the road :rolleyes:
anybody had this happen ??
peace-
johnny
If it is like mine, the lights are grounded right there with a rivet through the wire into the metal. It also sounds like there might be corrosion at the trailer plug allowing it to "jump" from circuit to circuit.
yeah- its has the ground strap that hits the screw and the trailer. Could that activate the break-away brake ? :confused:
peace-
johnny
Your brake controller controls your brake circut. Something is wrong in the wiring with the truck or the trailer. Hook it up to a diffrent truck and see what happens.
I removed the Clearance Light Base from the Trailer and everything is OK now. I just can't figure why the brakes were locking :confused:
peace-
Johnny
Thanks Red
Trailer was acting up again today, minnesota offered to pull the trailer, and sure enough, brakes were locking up again. a least i know the problem is on the trailer side:rolleyes: . The plug on the trailer is a sealed plug- can't undo a screw to get inside.
peace-
johnny
Have you checked the connections at the brakes? I am not an expert by any means but I have never heard of a sealed plug. Can you post a picture of the plug?
Found a Bad Connection
Found a bad connecton that was halfway pulled apart, was kinda hidden under some tape. Cleaned up the connection and took the trailer for a quick trip and all was good:).
peace-
johnny
scotch locks suck!
i dont understand why manufactures use scotch locks on trailer wiring! i think they are terrible and good for a temporary fix at best! nothing like some solder (sp) and shrink tubing if u ask me.
I agree It was a bit sad too see the wiring job..:( Might have to do some soldering soon.
peace-
johnny
