Mammoth Clear skies possible storm Friday - Saturday.
More likely to have more snow as go north from Mammoth.
Chances 20% Mammoth , 30% Truckee , 0% Sequoias, 60% Shasta
Vary in temps lows 10-20's highs upper 30's low 40's.
Wednesday, January 27, 2010 9:24:47 AM
SPLIT FLOW BLUES FOR THE CENTRAL SIERRA.....HOWEVER....THE PATTERN OVER THE ATLANTIC
WILL BE CHANGING OVER THE NEXT WEEK TO TEN DAYS....OFFERING TO CHASE THEM BLUES AWAY!
A SPLIT FLOW PATTERN IS EXPECTED TO CONTINUE THROUGH THE WEEKEND WITH BELOW NORMAL PRECIPITATION OVER THE CENTRAL SIERRA.
EXPECT FAIR SKIES TODAY WITH COOLER TEMPS AS A RESULT FROM YESTERDAYS SPLITTING SYSTEM. HIGHS TODAY WILL BACK DOWN INTO THE 30S FROM YESTERDAYS LOW 40S. INVERSIONS WILL TIGHTEN UP TOMORROW WITH A LOT CHILLIER AIR RETURNING OVER THE LOWER ELEVATION VALLEYS. UPPER ELEVATIONS, INCLUDING THE RESIDENTIAL AREAS OF MAMMOTH AND JUNE WILL WARM BACK INTO THE 40S. THE "POGONIP" WILL RETURN TO AREAS SURROUNDING MONO LAKE.
ANOTHER SPLITTING SYSTEM WILL EFFECT THE MONO COUNTY AREA FRIDAY NIGHT AND SATURDAY. SNOW SHOWERS ARE POSSIBLE WITH COOLING EXPECTED FOR SATURDAY AND SUNDAY.
OVER ALL.....
HIGH TEMPS WILL RANGE IN THE MID 30S TO LOW 40S IN THE UPPER ELEV'S THE NEXT FEW DAYS WITH OVER NIGHT LOWS IN THE TEENS AND 20S NEAR THE VILLAGE AT MAMMOTH. NO SIGNIFICANT WINDS ARE EXPECTED IN THE RESIDENTIAL AREAS OF MAMMOTH THE NEXT FEW DAYS.
JANUARY 27TH:
TELECONNECTIONS AND LONG RANGE:
BOTH POSITIVE PHASE PNA AND NEGATIVE PHASE NAO INDEXES ARE CURRENTLY LESS THEN 1 STANDARD DEVIATION OF NORMAL. THE NAO IS TRENDING TOWARD NEUTRAL OR EVEN SLIGHTLY POSITIVE BY LATER NEXT WEEK.
LONG RANGE ENSEMBLE MEANS TRENDS SUPPORT THESE TELECONNECTIONS DRIFTING TOWARD NEUTRAL DURING "WEEK TWO", SO FROM THAT STAND POINT, THE PRESENT RIDGING PATTERN OVER THE FAR WEST SHOULD BOTH DE-AMPLIFY WITH ITS AXIS SHIFTING EAST. THE EXCESSIVE WAVE LENGTH SHOULD ALLOW SHORT WAVE SYSTEMS TO PENETRATE FURTHER INLAND AS THE FLOW OUT OVER THE ATLANTIC OPENS UP ALLOWING THE FLOW OVER THE EASTERN PACIFIC AND EVENTUALLY FAR WEST TO BECOME MORE CONSOLIDATED.
THE ONLY ADDITIONAL COMMENTS THIS MORNING THE DWEEBS WOULD ADD, IS THAT THERE IS AN INCREASING AMOUNT OF MID TO LONG RANGE CONFIDENCE "THIS MORNING" VIA THE DAYS+ GFS MEANS, THAT THE PATTERN WILL TURN WET THE SECOND HALF OF NEXT WEEK AND BEYOND FOR CALIFORNIA. THE PATTERN IN THE LONGER RANGE CHARTS SUGGEST A TREND TO A PERIOD OF LARGER SCALE, PROGRESSIVE LONG WAVE TROFING THAT INITIALLY SETS UP A BIT EAST OF 140W BETWEEN THE HAWAIIAN ISLANDS AND THE WEST COAST. IT APPEARS THAT THIS TIME, THE FLOW WILL BECOME MORE CONSOLIDATED, AND WITH A MUCH LARGER CYCLONIC CURVATURE THAN THE LAST SEQUENCE WITH AN ADDED TROPICAL/SUBTROPICAL TAP. THIS APPEARS TO BE A MORE TRADITIONAL TYPE STORM SEQUENCE WITH A GOOD STRONG FETCH WITH PERIODIC ITZ TAPS. THE SUBTROPICAL TAPS WILL MAINLY EFFECT THE SOUTHERN HALF OF CALIFORNIA AS INDICATED IN THE PAST SEVERAL RUNS OF THE GFS 700RH. THIS IS ESPECIALLY TRUE FOR SOUTHERN CA.
AT THIS TIME....THIS IS JUST A GOOD STORMY PATTERN FOR CA...NO DOOM AND GLOOM FORECASTS LIKE SOME OF THE OTHER FORECASTS THAT ACCOMPANIED THE LAST SEQUENCE OF STORMS FOR CALIFORNIA. THE ONLY THING THAT THE DWEEBS WOULD ADD IS THAT SO-CAL HILLSIDES ARE PRETTY SATURATED FROM THE LAST SEQUENCE IN THE SO-CAL AREA. HOWEVER, I WOULD IMAGINE THAT RESIDENTIAL AREAS ARE PRETTY PREPARED BY THIS TIME.
UPPER JET:
THE UPPER JET AT THIS TIME APPEARS TO WANT TO SET UP MORE OVER SOUTHERN CALIFORNIA RATHER THEN NORTHERN BAJA. ALTHOUGH NOT IDEAL...THIS SHOULD BE A BIT WETTER FOR THE MAMMOTH AREA THEN THE LAST SERIES. ALL OF THIS OF COURSE IS SUBJECT TO ADJUSTMENT THIS FAR OUT, HOWEVER ALL VERY PROMISING. STAY TUNED>>>>>>>>>>>>>>
THE DWEEBER................
